HELP! Echo 9010 Blower
dmvaill
OPE Member
4:27 PM
Utah
I have a 9010 blower that was running and now it won't start. I checked for spark and I replaced the spark plug and the carburetor. I also replaced the grommet and all hoses and fuel filter. After doing this , It started then stalled and now won't start again. Does anyone have any ideas?
EFSM
5:27 PM
Extreme southern IL
Have you tried using ether or dumping some fuel in the intake to see if it is still starving for fuel? How about compression check of the engine?
Is the primer bulb full of fuel? On those carburetors, the lower/larger barbed fitting is for the pickup line, and the upper/smaller is for the return line.
EFSM
5:27 PM
Extreme southern IL
I was trying to prime it and no fuel was going in the primer bulb.
Then that’s your issue. Could be the fuel lines aren’t hooked up right, or it could be a broken metering diaphragm in the carburetor (very unlikely with this new of a machine).
