roloc1
OPE Member
- 11:06 AM
- Nov 8, 2025
- Seaford, DE
Looking at getting some spare Fuel Line to have on hand. I try avoiding using fuel that contains Ethanol, but if I'm working on someone else's equipment, that might not be the case. I've seen the crumbled hoses. Tygon seems to be a viable replacement, but what is used/recommended all the pros/experts?
My Echos use 3mm X 5mm and 3mm X 6mm lines. I was looking at Echo's 90014 (3mm X 5mm) and 90015 (3mm X 6mm) bulk hoses and read it is safe for fuels containing up to 10% Ethanol. Then I read on the boxes, "...Must Not be used on the fuel tank to carburetor inlet on engines/equipment built after 12/31/2011." Am I the only one this statement confuses? My saws were built after this, but these are the hoses listed in the IPL!
Thanks in Advance. Stay safe and blessed.
