MHHPartner
OPE Member
- 3:39 AM
- May 20, 2021
- Ponchatoula LA
Hello, all:
Own three Echos - 409, 590, and 680. Couldn't have been more pleased with them over the year that I've had them.
Last week cut up a neighbor's downed tree with the 400. Toward the end of the job noticed the chain was getting slack and shut it down to tighten it. Realized it was dry as a bone. I only had a couple of cuts left, so poured some oil on the chain and finished.
Got home and took the bar off and cleaned all channels and passages. No luck. I keep my saws clean, and the interior of the oil tank was spotless.
Even with the bar off no oil came out with it idling or blipping.
Figured it was a freak failure of the oil pump and put it aside to take it in for a warranty repair.
Pulled out the 590 today to cut down a few trees, and you guessed it, it quit oiling. Repeated all the cleaning, checked the filter in the tank, and turned the pump up all the way. Nothing.
The only common denominator was a no-name bar and chain oil I was using for the first time. Dumped it out and refilled with one of my standard brands. Nothing.
After reading what people use for bar oil, I can't believe that's the problem, but is it possible the new oil clogged or torched something in the oil pump on both saws?
Thanks for any ideas or guidance.
