psuiewalsh
Basement Bodging
- 8:58 AM
- Dec 23, 2015
- Nottingham,pa
There was a loctite product and some people said it worked on 064 cases with bore issue s
There used to be some cases on ebay for decent prices. Not sure how that stacks up against new case halfs.
How does the crank look over all? Is there a lot of wear on the clutch bearing surface or anything like that?
Dahmer you have seen this in other saws?
I tried to pull a bearing out of my homedepot makita and that sucker was in there. Heating and pressing it wouldn't budge with the amount of force I was willing to use.
I have used the 620 at work several times with great luck. I have never tried it on crank bearings though. Have you measured the bore to see how far off it is? It would be interesting to see if it is worn equally in all directions or if it is only worn towards the front of the case from the tension of the chain.I could see it working if we were talking about a case that was worn just enough to let the bearing slip out. However I'd be worried about alignment issues on a case that's really sloppy. That stuff does work though, in the right application.
Edit: here's what I have at work. The loctite 620 says it'll take up .015" diametrical clearance. Needs to be heated to 450° F. to release.
A Solo 665-681 crank will fit if you’re up for a bit of modification, adds 1mm of stroke.Does anyone know the differences in the cranks over the years? I recently picked up a 7900 with a blown lower rod bearing. Looking at the different IPLs I see 038-120-100 listed for the 6400/7900 and 038-120-200 6421/7901 saws? I haven't been able to find a decent used crank yet but don't know if either part will work or if it has to be 038-120-100? Thanks.
If you are replacing the crank it's not beyond your abilities.
And this thread will show you every piece you need.
Here, I'll help :
https://www.ebay.com/itm/Original-Ersatzteil-Solo-Kettensage-675-Kurbelwelle/222335346632?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160908131621&meid=92f2bae5ab3043ad8029c23cca57bb9f&pid=100678&rk=10&rkt=10&sd=192137283279&itm=222335346632&_trksid=p2481888.c100678.m3607&_trkparms=pageci:9a1b49ac-24de-11e9-8bdf-74dbd1803c39|parentrq:a0e244901680aa11adc869e8ffe8bb19|iid:1
If you can replace a crank and use a dremel, you can do it.Thanks for the info but I think that might be beyond my abilities at this point.
http://opeforum.com/threads/stroking-a-dolmar-7900.14462/
Yes, yes I finally showed up. I'm not on OPE as much as the other site. Thanks for the tags @dahmer. Got two of these saws now, a 6401 that had both blown main bearings, and wallowed out races, bent crank and the bearing was spinning on one side of the crankshaft. The 6421 that was purchased to build because it was 'running' ended up having a blown clutch side main bearing, and a enlarged oil seal race on the clutch side. This one also had excessive wear where the clutch bearing rides on the crank. So... I can put together a saw assuming I can find a solution to the crank and do something about the oil seal issue, which the case is only over-sized by about .002-.003''@Mac&Homelite is fighting a 6401 that he was converting to 7900. Clutch side crank bearing fit is wore oversize and it also messed up his crank. He can give you more details than I.
