Dolmar 64xx/73xx/79xx series, smurfs and solo 665/675/681 thread
David Young
Safety First !!!!!!
3:58 PM
vt
what are you using for a formula?
3:58 PM
If you don’t have a degree wheel. Put a line from your jug to your flywheel. Then put another line 5 mm to the left. And advance it that much. 5mm of movement is roughly 6 deg.
:icon_popcorn:
I checked with your way a bit and calculated roughly 4.5 -5 mm movement with 1/3 or .025 off key. Close enough for me. It’s hard to grind that cast key/measuring it and I don’t wanna risk taking too much off by accident.
3:58 PM
If stock timing was around 28 degrees like mentioned previously in the thread and I got 3-4 more degrees advance I should be in the 31-32 degree range on the money in theory... my head hurts now lol.
AlfA01
10:58 PM
Evia, Greece
It would be awesome to see what gains can be had on a stock 79XX from advancing timing only. I've heard mixed opinions on advancing the timing on these, but usually those are coming form various guys that are porting them.
Hedgerow
2:58 PM
Don’t forget, the OEM coil has a timing advance built in.
272 coil don’t have it.
9:58 PM
Depending on price, I’d like a set of the small spikes
I'm interested if they aren't made of gold prices.:thumbsup:
I can do the following!
Please make sure we are talking about the same spike set!
Small European spikes:
- outer EU style , part # 957 250 060 - 13 Euro
- inner EU style , part # 038 250 021 - 15 Euro
- shipping to the US 100 - 249 gram package - 9 Euro
SUM: 37 Euro/set shipped (with tracking number)
@Adirondackstihl & @Woodpecker , are You interested in a set each or passing up?
I am not trying to be pushy, I just want to know where we are at with this.
Please let me know.
Adamski
Plebus Splederns
8:58 PM
Essex, UK
What did you use to polish that muffler?
Yes they are in need of a D handle too.. I started mine (recently acquired this week) this morning and found it harder to pull over than my 281xp. I was surprised. It does however have a teeny handle on it.. or is this the standard size??
9:58 PM
Hard to tell, but I think that doesn't look like a OEM handle.
Mine look like this.
Dolmar PS6400-PS7900-00.JPG Dolmar PS6400-PS7900-01.JPG Dolmar PS7900-07.JPG
