Dolmar 6400 BB spun crank & other problems
BuckthornBonnie
4:22 PM
Penn Yan, NY
Problematic Dolmar with 3yrs average run time on an AM big bore kit. Wouldn't idle, carb wouldn't tune/- piston had excessive wear but no scoring. Stripped it down and found this:
"Spun" crank, flywheel side. Slip fit into both old and new bearing. Had a noticeable rock with flywheel off.
BuckthornBonnie
4:22 PM
Penn Yan, NY
And-
Caber rings, HD filter upgrade.
I didn't build this saw, but did supply the kit from Weedeaterman... I liked the looks of it.
Here's the kicker- my buddy never told me that he noticed the crank play. He asked a local mechanic who said it's probably fine. Lesson learned; only build a saw on a good bottom end. It'll eventually fail if you don't.
Angelr
10:22 PM
Galicia España
[QUOTE = "BuckthornBonnie, post: 517151, member: 1725"] Y-
[Adjuntar] 90418 [/ ATTACH]
[INCLUIR] 90419 [/ ATTACH]
Anillos Caber, mejora de filtro HD.
No construí esta sierra, pero sí proveí el kit de Weedeaterman ... Me gustó la apariencia de eso.
Aquí está el pateador - mi amigo nunca me dijo que él notó el juego de manivela. Le preguntó a un mecánico local que dijo que probablemente estaba bien. Lección aprendida; sólo construir una sierra en un buen extremo inferior. Finalmente fallará si no lo hace. [/ QUOTE]
I've seen that in more cylinders, I do not think it's a crank problem
BuckthornBonnie
4:22 PM
Penn Yan, NY
Thorough inspection saves a lot of heartache my friend, lesson learned. Snag some parts from some of our illustrious members here and put some good oem parts on the Ole girl. @Miller Mod Saws
Yep. I never build up a questionable bottom end. He got bad advice lol.
TreeLife
I'm Dominick
4:22 PM
If it was me I would contact Mr miller for the bearings and perhaps a ported top end and new piston. It will really rip after that, Carl knows his way around a Dolmar.
BuckthornBonnie
4:22 PM
Penn Yan, NY
Poor plating quality? Dirt ingestion?
BuckthornBonnie
4:22 PM
Penn Yan, NY
We are thinking of parting it out.
BuckthornBonnie
4:22 PM
Penn Yan, NY
I can't like this lol
Haha, it's sacrilege.., I know.
Anyone need parts? Pretty much everything else is ok. I think my buddy is done with it, but I'll confirm.
We could probably trade for a decent 046-660 project (w cash on our end if needed).
It had previously scored the original top end.
SOS Ridgerider
Muffler Modded Member
4:22 PM
Central CT
Post up some pics of what you have, and what you're looking to get for it. I'm always looking for Dolmar stuff.
BuckthornBonnie
4:22 PM
Penn Yan, NY
F-Cast rings?
Ahh... Good question and I thought the same thing at first.
As far as I know it was a regular Caber ring. It made decent compression but nothing great. I ran this saw a few times--/ it was "ok" and comparable to an 044/440 (despite being 85ish cc).
BuckthornBonnie
4:22 PM
Penn Yan, NY
Tank, handle, 2 carbs (one AM), 32"bar, 18"bar (maybe), air filter upgrade, newish AV, all fasteners... should be used but in decent shape.
The case worries me: it had a failed case gasket that someone epoxied (that failed, too). The case screws came out in what I can only describe as a "biased" feel. There's a few signs that it was dropped. I wonder if it was dropped hard enough to load the crank/bearings and cause this failure.
blsnelling
Friend of the Riff Raff
4:22 PM
Franklin, OH
I think F-Cast rings now come standard on most pistons.
