Dolmar 133
Fruecrue
certified hand catcher
9:54 AM
Alden NY
I measured 155 psi when I received the saw, with carbon in it. Cylinder must have been dry.
This was a pleasant surprise as I don’t plan any machine work due to piston and cylinder shape.
I’ll be happy if it stays the same when I delete the .020” base gasket and raise the exhaust port some.
Fruecrue
9:54 AM
Alden NY
Without base gasket, exhaust at 106, transfers at 122, intake at 66.
Measured the bore at 2.044”
Smallest skirt width exhaust side is 1.428”
65% of bore diameter is 1.329” which would leave almost .050” at each side.
The goal will be raising exhaust to 101.
Intake needs to move from 132 duration to about 156.
Scribed the piston at 78* and measured .2” to bottom of skirt.
I may need to take some from the port and some from the skirt to avoid getting into the impulse port.
Lee H
6:54 AM
cape cod ma.
Just to much going on this year.
I am amazed at the amout of oil these things put to the bar. Its almost 1:1
You can adjust the oilers John. Up from the bottom behind the clutch you will see a screw.
Your saw sounds awesome, The 133 is a great performer in stock form at 85cc's.
Redfin
Meh...
9:54 AM
Central Pa
Yepper I did see that Lee. Im just happy it oils now. Getting the clutch off this thing was quite entertaining.
