MattG
Chainosaurus Rex
- 2:24 PM
- Apr 30, 2017
- Cambridgeshire, England
Hi Jim,Most carbs have a little casting mark to pinpoint where to drill the hole if the carb is designated for an intake block set up. Here's a WJ39 from a husqvarna 394, and a WJ48 from a stihl 066.
You say the carb you pictured has a problem. You will likely need to drill a hole in the location pointed out to complete the impulse passage.View attachment 104934
The carb came out of the factory with that outer port blanked - and it ran fine for years like it.
I assume Zama must have designed this particular carb that way. Note this is a S126B, and I've not found anyone yet here with a genuine similar carb. I chatted to Lone Wolf the 200T guy, and he had only S126A - which have the hole drilled as expected. I'm assuming that the S126B is more a european thing than a US one?
