DIY Nikasil...Is it possible on a blind cylinder
AlfA01
11:22 PM
Evia, Greece
In my many YT subscriptions is this guy here in Europe that does a lot with two strokes. He mainly does small engines that are liquid cooled for small motorbikes from what I've seen.
In the video series I've been watching lately, he's doing a DIY nikasil coating in a cylinder he cast himself. I'm curious if it could be done DIY on a blind cylinder for a saw. Definitely would be feasible for a two piece head race saw.
Part I
Part II
Part III
Part IV
Machining
KYsawman
4:22 PM
Gone Fishing
I think the blind cylinder causes trouble. I used to have snowmobile cylinders replayed. They where two piece cylinders.
AlfA01
11:22 PM
Evia, Greece
I know it's difficult and I had pretty much given up on getting them done due to cost. Here in the EU no one does blind cylinders that I've found.
Outback
1:22 PM
Oregon
I love that guy, he never quits. I've been watching him for a couple of years. 2 stroke singles are more or less the same. You can learn a lot from someone in a similar, but different field of exploration on the same subject. Plus who doesn't love the dyno too.
Deets066
AKA Deetsey
4:22 PM
US Chrome is the only place that I know of that does blind cylinders. If most places that specialize in plating shy away from blind ones. I’d say doin it in the garage won’t get you the results your looking for
AlfA01
11:22 PM
Evia, Greece
Agreed, but I do keep hope of one day revitalizing these 2100 cylinders I have with missing plating. Cost to benefit just isn't there considering the re-plating cost and shipping.
Stevetheboatguy
3:22 PM
Nw IL
Would it be cost effective to have L.A or Advanced make you a iron sleeve? Or isn't there enough meat to bore it for a liner?
Sounds backwards, but if the alternative is the trash can why not? Iron sleeves will hold up for a long while, just not as long as the plated.
Steven
Deets066
AKA Deetsey
4:22 PM
Steven
I just don’t think there is any gain over getting it plated. You’d still have cost and a lot more work. I don’t see it being practical
Red97
4:22 PM
MI
Steven
I tried one...
Seems the jug had enough meat to hold the sleeve.
Not sure the cylinder had the correct cooling area to work with a sleeve?
About .0035-.004" clearance and it still seized.
@huskihl
4:22 PM
I tried one...
@huskihl
Yep. Not sure if the pistons aren't right for a sleeve. Or maybe the rings. Or maybe we still didn't have enough clearance. I warmed that Echo up a good 5 minutes and the piston swelled up faster than the sleeve could.
Stevetheboatguy
3:22 PM
Nw IL
I tried one...
@huskihl
10-4 was just a thought. Figured cooling or expansion might have been a issue, but wasn't sure. A bunch of air cooled atvs and some older saws have iron liners. But then again they aren't usually turning 10k +.
Steven
Bigmac
1:22 PM
Oregon
I tried one...
@huskihl
Mcculloch recommend .007 in there 125cc kart motors with iron sleeves. I do notice less of an issue in liquid cooled bikes, but also noticed a longer warm up time for the plated cylinders
4:22 PM
It’s not the plating that’s the issue, it’s the final honing that is. A blind cylinder requires special tooling.
Probably easiest to make a head Dan, then get the open jug done locally.
I bought a bunch of stuff to try home Nikasil, but after watching the videos above, I felt it was a bit much work for the amount I’d be trying to do. Also, out of my league to be honest.
AlfA01
11:22 PM
Evia, Greece
Looks like the only way possible, Al. I'm in no rush. I've just been watching these vids lately, so I thought I'd post them up and see what others thought.
4:22 PM
I watched them all. The guy is impressive. The undercover scotch beaker is quite funny.
I bought the finest carbide powder I could find and Nickel Chloride, as I am already set up to Nickel electroplate and have done so many times.
After watching the actual process, I decided to bow out of it. A lot more involved than I had ever imagined.
Chroming the bore might be easier. I’ve also wondered how straight Nickel would hold up, as most chrome plating is Nickel based, the chromium is just the clear coating.
beaglebriar
The Peanut Gallery
4:22 PM
Warren Center, PA
I have box full of dead cylinders to send you when you get it figured out. [emoji16]
AlfA01
11:22 PM
Evia, Greece
Lol. Thanks DJ. I ain't that ambitious about it just yet.
