Dimensions of Echo Fuel Hose
hotajax
3:52 PM
Eastern PA
On Echo weed whackers and other small stuff, what is the dimensions of that skinny black hose that runs from the fuel tank, through a grommet, and up to the carb? Is that 1/16 of an inch or smaller than that? Thanks. I'd like to get this stuff in a roll.
hotajax
3:52 PM
Eastern PA
Junk Meister: What is 90014? Is that a grade of hose or it an Echo number? Thanks.
3:52 PM
3 x 5 is normal for most chainsaw applications. Weed trimmer line might be smaller, I’m not certain.
Has anyone used 3 x 6 Echo line in a 3 series husky tank or is it way too big?
Junk Meister
2:52 PM
Nebraska
I will double down on your question. I remember reading somewhere that Echo line was not as prone to sucking shut or collapsing but I am wanting to use it in my 3 series (and Jonsered) saw instead of paying For the cute lil piggy tails. It is frustrating to put a line in and have the fuel leak when the saw lays on its side.
Junk Meister
2:52 PM
Nebraska
I will be trying it out in a week or two and will try to revisit this thread with results.
Junk Meister
2:52 PM
Nebraska
Yes 90014 and 90015 are both Echo numbers I have read that you want the real McCoy not the AM crap... You will notice the difference in short time.
hotajax
3:52 PM
Eastern PA
Thank you sir. I noticed all my stuff is a little wet between the carb and tank. Prolly time to change all the stuff out. Thanks again.
AVB
2:52 PM
Elora, TN
Don't know if it will fit but my experience with 3x6 is that it is way too stiff to allow filter to move around in the tank.
3:52 PM
3x6 echo is in all my 281/288s that didn't need the and all those those oem and china 365/371/372s I built
No ill affects
I don't recall forcing them in.
3:52 PM
No ill affects
3x5 fits. Doesn’t leak, but it’s not really tight enough. I figured 3x6 was too big
Junk Meister
2:52 PM
Nebraska
I used the 90015/3mmx6mm on my 2152 and it fit nice I blew trough it wit no restrictions but I it does seem stiff (post 11) and I think when I get it running I will find out if I can use most of the tank of mix or if the "stiff" only lets me burn off the top half. I am going to get a different filter 'cuz the one I put on is fatter than I want to see and may not lie as close to the bottom. CZED (post 12)You say no ill effects = my question is about how much line did you let dangle in the tank? I kind of guesstimated as the tank is off so I flopped and flipped the tank around as I watched how the filter moved around. I think it won't drain the tank dry but time will tell. I have several of these Jonsered 21 series I am kind of working on all at once and the length might become an issue , Should leave an excess in the tank until I get it figured out. The roll of 3mmx6mm had four sections of 90 " pieces. that caught me off guard vendor listed it as 26' and box stated 26' got more than expected.
I put a bit of WD40 on line outside of tank and pulled and stretched the line through without much trouble (The stretch made the hose
This 2152 is getting a new OEM top end, and I am waiting for a carb kit. will be a while before I have it running.
The work bench is full of stuff and my freezer Lid has 4-2159s'and a 359. I have a 345 and a 2150 needing these fuel lines as well .
Junk Meister
2:52 PM
Nebraska
No ill affects
About how much hose did you leave dangling in the tank? Thanks
3:52 PM
Enough for the filter to lie horizontal
And reach both sides of the tank
It will soften a bit when immersed in fuel
All of mine flow fuel from any position.
Junk Meister
2:52 PM
Nebraska
I never considered the softening part ,, Thank You for the info. I was needing that.
