- 6:24 PM
- Dec 3, 2015
- Banner Springs Tennessee
Read more books on the theory of two-stroke motors. Do the math. Read some more. Think about what is happening in an engine rather than rely on people answering your questions first.
I have been reading the lets talk transfers thread and it has been very informative. It's a lot to take in, I also have been reading up on 2strokes. Bit understanding how they work isn't the same as understanding what numbers work where and why manufacturers choose the numbers they do and why monkeys in their garage put them where they do.
Sent from my HTC One using Tapatalk
Now we are getting to the good stuffnope miss that one cuz.View attachment 11670
For a piston port motor it should be fine to divide total duration in half.Bump
I'm using the @Red97 digital degree wheel, it works great and is easy to use, but I can get a degree or 2 difference in port height depending on reading before or after TDC. I assume this is because the magnetic gauge sits slightly off center from the shaft in its holder? Will averaging the 2 readings give me an accurate port height? That's what I've been doing. It seems to work well for finding TDC by using one port for reference, setting zero, then finding duration, divide by 2, set the gauge to read that half way value, then set zero again.
Bump
