D110 Not starting
Redicliff
Active OPE Member
3:02 AM
Lake County CA
The battery tests 12+
Key start produces one partial crank.
Time line:
First symptom occurred after running.
Short rest.
Started.
Short run.
No start same symptom.
see D110 no crank
Comments, advise and shared experience appreciated
EFSM
5:02 AM
Extreme southern IL
What engine? Sorry I didn’t watch the video.
If it is the single cylinder Briggs engine, most likely the ACR on the camshaft failed. It is a small spring loaded weight that reduces the engine compression during cranking. These are a very common failure item, and they can fail at any time, especially if the engine has kicked back during startup. Pulll the OHV cover and make sure the lower valve (intake) is bumping open when the piston is reaching TDC on the compression stroke. If it isn’t, then the ACR has failed.
hacskaroly
2100 Fanclub Member
3:02 AM
Northern Idaho, Ehh
This will be interesting, I think I have the same if not similar mower and it is doing the same thing. It failed last fall and I have not gotten back to it. I need to get a new batter before diving deeper, but had used it and tried it again the next day and no start.
066 redeye
8:02 PM
Tasmania,Australia.
I would also say cam decomp.
If it stops winding at TDC turn flywheel by hand just past TDC and try again.
Post up results.
Redicliff
Active OPE Member
3:02 AM
Lake County CA
Here's report so far:
1. Found out how to kick start (
to get mower out of the walnut grove
2. Tried the magnet on a wire probe to try and locate ACR pieces in pan = no conclusive result
3. Adjusted valves: No joy.
So, despite #2 failure, I'm figuring it must be the ACR failure.
4. Ordered new OEM Crankshaft with ACR from PartsTree = $135 delivered
Not easy to locate a small engiine repair shop in our area and everyone is pricey these days.
[the John Deere Dealer in adjacent county has shop rate = $210/hr and quotes job as 5 hrs]
[ local guy is $85/hr and estimates 4-5 hours with initial diagnostics @ $75]
In any case, not easy to transport the D110.
Maybe I'll have to tackle it myself. We'll see.
hacskaroly
2100 Fanclub Member
3:02 AM
Northern Idaho, Ehh
I have an older tiller that has a Briggs engine, since it wasn't working (found it at the dump) I figured what can it hurt to take it apart, clean everything really good and put it back together. It wasn't as complicated as I thought it would be and was able to clean everything up really well. My biggest worry was the condition of the carb, but that didn't turn out to be an issue as when tested the engine fired up and ran. If you have the time and space, I would say go for it and give it a shot, that is what I would end up doing. No way I could afford JD to do the job!!
Redicliff
Active OPE Member
3:02 AM
Lake County CA
I watched the youtube video on the Crankshaft swap. Maybe in my younger days. For now, hoping a local, skilled acquaintance is up to the task and willing. Suffering the down time though.
Redicliff
Active OPE Member
3:02 AM
Lake County CA
Color me "amature" or maybe I'll play a "senior excuse card". Even after watching he 'How to video" Neglected or order these necessary gasket & seal. Doing that now.
Thank you.
P.S. I don't understand your post "signature": 2x066...et.al. ?
hacskaroly
2100 Fanclub Member
3:02 AM
Northern Idaho, Ehh
Those are the chainsaws in his collection - two Stihl 066s, Stihl 066 with small tank/large crank...etc - looks like all Stihl chainsaws
EFSM
5:02 AM
Extreme southern IL
Post up results.
I’ll probably be visiting Tasmania in a couple months. Anything I should add to my bucket list to do while I’m there?
066 redeye
8:02 PM
Tasmania,Australia.
Thank you.
That's the saws I have.
066 redeye
8:02 PM
Tasmania,Australia.
Everywhere is just great.
Just don't expect to drive around the state in 3 hours as most visitors expect to do.
Lake Pedder,Gordon Dam,Mt Wellington,Cataract Gorge,Ben Lomond,Various state reserves just to name a few.
