Cutting cylinder base.
Trader history (1)
Funky sawman
Pony Power
8:16 AM
North idaho
Looking for someone to cut the base by .020 on my 357xp cylinder. I am going to experiment with some light port work, but I have no access to a lathe. I'm retaining the base gasket with this build.
After January I will have some down time due to spring breakup conditions so I will yank the head then. PM price for said labor, thanks
Dolkitafreak
Dolkita686
11:16 AM
Central Ohio
Have the band cut as well if you can grind upper transfer ports. You’ll see lots more compression and gains.
Ronie
11:16 AM
NC
redline4
I'm huge in Japan
10:16 AM
Rosholt Wisconsin
Yea I don't have a right angle grinder. All I gots is a Dremel tool
It's not ideal, but you can use the adapter with the screw in the end and small cutoff wheels to work in the upper transfers.
I used that in my 357 to get it to where I wanted height wise, then used a round ball to get at what I could for shape and angle.
It runs pretty good considering I'm clueless.
srcarr52
11:16 AM
Iowa City
Most port work in the 80's was done this way, before RA handpieces where readily available. It's slow and easy to make a mistake... but it works.
NorcalFlyingsquirrel
8:16 AM
Santa Cruz Mountains
I have a ra but still use a round edged disk diamond coated for most of my work in a 2511, 201, etc and do most of the work in a 200 from the top. The little ra's are a *b-word to hang onto in little cylinders but if you want one i got mine here on ali express for $40 and it does the job on larger cylinders. I have a harbor freight flex shaft but it requires a little finessing ever once and a while and is not compatible with standard foredom shafts https://www.aliexpress.com/item/1005003274497933.html
