Cub cadet zt1 42”cut question
Jcy865
New OPE Member
10:10 AM
Central Ohio
Hi, this is my 1st zero-turn. It is a 2020 with 170 hrs, when I engage pto the whole deck jumps. Today I removed the belt,checked all spindles and pulleys..everything seems good. I’ve had it going on a year, read online where quite a few people complain about it dying when it engages..never had that happen. Any ideas or is this just the nature of the beast…Thanks
ammoaddict
10:10 AM
Granite Falls, NC
So it's done this since you've owned it or just started? Electric PTO clutch?
ammoaddict
10:10 AM
Granite Falls, NC
No, not factory
I had an old Murray rider 40" . When the factory blades wore out, I put gator blades on it, twice as thick and heavy. The deck would shake when I engaged the blades until it got up to speed, then it would smooth out.
EFSM
9:10 AM
Extreme southern IL
Nature of the beast, especially if the blades are heavier than stock. The lighter the deck, the more it jumps. 42" deck like yours doesn't weigh much.
