Matt D
Hello everyone,
So I picked this saw up last year because it was on Craigslist for real cheap because the bar studs fell out and the repair shop the guy took it to said it wasn't worth fixing. I got it home, replaced the studs, fired it up and did a little cutting with it to make sure it ran and put it away. I don't heat with wood so I really only use saws when there's storm damage or a friend needs a hand taking down some trees. I gassed the saw up yesterday and cut up some wind fallen trees from a previous storm and the saw has good power but it tends to bog when deep in a log and I noticed it likes to load up when idling after a few seconds. My first thoughts are it needs a tune up including fuel filter, carb kit and spark plug. Am I correct it my assumption or is there something else that could be causing the bog when the saw is in wood?
Most times when it started to bog I could lift it out of the cut a bit and it would pick back up and I could drop it back in and get through the cut. I feel the saw should have plenty of power to cut through the size logs I was without any bogging. I decided to come here to ask the experts there thoughts? I don't mind spending a few bucks getting the saw in tip top shape since I got it for so cheap but I don't want to just throw parts at it so I figured I would ask the experts before I break out the credit card and start ordering parts.
Thanks in advance
-Matt
Thanks in advance
-Matt
