Crankcase bearing question
Mark71gtx
11:38 AM
Fuquay Varina, NC
I am finally getting around to working on my Husqvarna 2100. My crankcase had some broken spots on it, so I bought a crankcase on eBay for it. I removed the bearings for replacement and the clutch side didn't really want to budge. I added more heat and finally got it out and found that it has been pricked at some point. I am assuming that it had spun a bearing at some point. My question is, do I use Loctite 660 on this bearing, or something else? Any input is appreciated.IMG_20170215_203534285_HDR.jpg
jacob j.
Only the weird
8:38 AM
Coastal Oregon
If the bearing was a good, solid fit- I'd throw a little 660 in there and run it.
Mark71gtx
11:38 AM
Fuquay Varina, NC
It was certainly holding on. My only concern is how did they determine that the side that they pricked was the side that was worn? I guess the wear marks would have made it fairly obvious when it was broken down. I guess I am just being paranoid since some of the parts for this saw are so scarce.
11:38 AM
Loctite makes a product called press fit .I used same on a repair of an 048 years ago ,have had no problems since .
Derf
11:38 AM
Long Island NY
It isn't necessarily that the bearing spun, and this was a fix. Sometimes when installing a bearing it just feels loose. Pricking around the bearing seat will tighten that up. So it's more of a preventative measure. So long as the new bearing is a good press-fit when you insert it, that should be no problem to lose sleep over. In either case, you should be fine with or without a little loctite.
