Stackowood
- 12:10 PM
- Dec 17, 2016
- West coast
Looks good! Let us know how the case goes together.
I made the tools to mainly press the seals in square. That has been one of my biggest concerns. It'll be much better than the hammer and socket approach IMO.Am i missing something here heat case untill bearing falls in wait alittle keep heating case untill crank can be inserted inside bearing hold for a few then apply sealer and case gasket then to the same to other case half no tools needed. I did a 372 this way no hassles after bolted installed seals Easy peasy
Yes some seals arent flush with bearing but further in
See how it goes. I may take you up on that.let me know if you want to borrow the tap![]()
looks awesome!!!Here's what I came up with. I have a 372 ready to assemble so we'll see how they work.![]()
not necessarily easy peasy.... i've done enough to get good enough with this method you describe, but its not nearly as controlled and predictable as with these tools ... i think its easy enough to drop a cold crank through a warm bearing... but to then have the other side ready to go and hot and sealer etc all at the same time... and then it gets stuck, and then the rod is hanging ya up etc, pins aren't aligned, and then the crank isn't cold enough, and then you have to pray that the case bolts will bring the whole thing together AND then there is lateral force on both bearings. I am capable of doing this and have done it a bunch of times. with enough frustrations, I think the right tools are easy enough to make and cheap enough that it makes sense to use them. I hope to prove this when my 660 and 372 clones show up. ...vids will be forthcoming in that event.
Please correct me if iv the wrong end of the stick here ...but are we not talking about pulling the crank into fitted bearings ? In the case .Yes im that guy. I just use heat room temp on crank I dont like the idea of forcing steel bearing races into alum cases when heat is needed and they drop in. When i do a case i do the clutch side first then let it coolto touch then sealer gasket sealer then marry the fly wheel side and tighten screws smack it once or twice to free up
We have the skf induction heater as well. It's a huge time saver.i take my cranks and shafts to work now. we have a 2000.00 skf bearing heater works perfect
