Clint's P60
3:45 PM
Chainsaw Jim
Con Artist LLC
1:45 PM
Springfield Oregon
Mine may show up grey too Jim but I dunno. If it shows up black then I'd like to do an even swap for they grey one since Clint saw is getting restored.
I do believe I deleted that before you replied!, lol.
I have some black tubing on its way so I can change out the grey. No need to make any sacrifices.
T.Roller
4:45 PM
Southeast, TN
Ok sounds good. Clint is a good guy and I like to help when I can. Sorry if I was being a dick I was just excited I may get a black one. So what are you thinking on the port work?
Chainsaw Jim
Con Artist LLC
1:45 PM
Springfield Oregon
He likes running longer bars so I'm going to target the low end torque. It might want a thicker or stronger reed petal for that.
p61 western
Ol Mudflap
1:45 PM
GFY
Curious to hear how this works out and what tubing you used.
Chainsaw Jim
Con Artist LLC
1:45 PM
Springfield Oregon
I already bought and installed the Boyeson reeds on this saw... I kinda jumped the gun a little bit, seeing as how the saw needed new crank bearings.
I noticed those and I think they're a good looking set up. I'd like to see the difference in performance between those and the two stage set I fabricated. My secondary petal looks like it may be quite a bit softer than the Boyesen.
cgraham1
1:45 PM
Nor Cal
I still have the stock ones laying around here somewhere, too...
T.Roller
4:45 PM
Southeast, TN
I'm new to the reed valves. What would the softer reed do? I know my stock one was thin metal.
Bigmac
1:45 PM
Softer reeds are for low end and stiff is for top end, if the reed is to soft it won’t close at high rpm, and the engine will hit a wall. I have done a lot of testing with banshees. If you can get stuff but light reeds, that kind of the best of both worlds, it was night and day difference on a 10mill banshee, the low end reeds worked fine until the higher rev pipes and drag porting. I think there is a fair amount of grace room, but if you get it just right it can make big gains
