- 9:53 PM
- Dec 29, 2015
- Ontario, Canada
038 intake tube? What carb you running?I'm sure it could be better, but it don't run to bad
Who saw the bar nut go flyin in the vid? Just now noticed it's missing. Guess I didn't tighten em enough.![]()
I've got a zama and a lathe. Anybody found out how much is too much?A zama that I did a little grinding on
Did you see CFB's 036 thread?I've got a zama and a lathe. Anybody found out how much is too much?
Yeah I can throw the tilly on there, I do also have a 38 carb as you said above. The Venturi may be the same but the fuel circuits are different. I'm gunna try that one out tooDid you see CFB's 036 thread?
He's running the 038M bing on his and the saw has a lot of zip to it, better than the Zama.
The Venturi is actually smaller than the stock Zama's. We spoke about it and think that there may be a difference in fuel delivery at "in the cut" rpm.
I just got an 038 Zama in off eBay. Venturi the same as the 036 carb, so don't waste your money there, I did that for you.
@Deets066, if you have the time, can you swap a stock 036/034S carb on this Saw and see if there is any difference in speed and/or idle quality?
Stihls are good boot anchors I hear... you should have put it in the back of the truck to help weight it down for more tractionWhooee this is one stinky squeel
Sure sounded good, can't wait to run it. Great meeting you tonight Deets. Thank you for the shop tour as well.
Pull the closet rod down and make a few cuts right in the apartment.... vid of course
