AlexStromberg Epic gamer Local time 7:07 PM User ID 23149 Joined Apr 12, 2022 Messages 201 Reaction score 609 Location Sweden Nov 17, 2022 #1 Hi! Just pulled the cylinder on my new to me 238SG and it has a chip in the intake port. Should I be worried? I cant feel all the lines in the bore, the flash makes it look worse than it is.
cus_deluxe terms of service violator Local time 1:07 PM User ID 393 Joined Jan 3, 2016 Messages 5,643 Reaction score 27,021 Location Michigan Nov 17, 2022 #2 nah, hit it with some 320 grit and fuggin send it
kneedeepinsaws Pinnacle OPE Member GoldMember Local time 11:07 AM User ID 12933 Joined Jun 21, 2020 Messages 805 Reaction score 1,714 Location Oil Country Nov 18, 2022 #3 Looks like a chunk gone on the edge of the port to me. what does the piston look like on that side?
AlexStromberg Epic gamer Local time 7:07 PM User ID 23149 Joined Apr 12, 2022 Messages 201 Reaction score 609 Location Sweden Nov 19, 2022 #4 kneedeepinsaws said: Looks like a chunk gone on the edge of the port to me. what does the piston look like on that side? Click to expand... Piston looks completely fine
smokey7 Pinnacle OPE Member Local time 1:07 PM User ID 761 Joined Feb 3, 2016 Messages 1,558 Reaction score 3,602 Location Detroit Nov 19, 2022 #5 Knock it smooth with a bit of grinding and sanding. If it was me i would lower the port evenly all the way across the port.
AlexStromberg Epic gamer Local time 7:07 PM User ID 23149 Joined Apr 12, 2022 Messages 201 Reaction score 609 Location Sweden Nov 19, 2022 #6 smokey7 said: Knock it smooth with a bit of grinding and sanding. If it was me i would lower the port evenly all the way across the port. Click to expand... Lowering the port was also an idea i had. Buy maybe it will be lowered too much?
Dolkitafreak Dolkita686 Local time 1:07 PM User ID 7904 Joined Nov 19, 2018 Messages 541 Reaction score 1,798 Location Central Ohio Nov 19, 2022 #7 AlexStromberg said: Lowering the port was also an idea i had. Buy maybe it will be lowered too much? Click to expand... Nope you’ll be okay. Grind it, then chamfer!
AlexStromberg Epic gamer Local time 7:07 PM User ID 23149 Joined Apr 12, 2022 Messages 201 Reaction score 609 Location Sweden Nov 20, 2022 #8 Dolkitafreak said: Nope you’ll be okay. Grind it, then chamfer! Click to expand... I'll do that, then the problem is completely gone
