SOLD Cherry Dolmar 5105
Trader history (4)
Ronaldo
4:49 AM
Eastern Iowa
Mine hasn’t leaked much and not every time I fuel. I stop short of filling it clear up to the neck and that helps.
Woodbutcher56
5:49 AM
N.W. Ohio
Mine leaks a fair amount every time I refuel. Open and close the fuel cap.
Ronaldo
4:49 AM
Eastern Iowa
Perhaps you nipped off more material than I did. I’ve done two saws and neither one leaks much. A little spot of fuel on the tailgate is all I’ve ever had. I was instructed to just nip off a bit of a corner on the duckbill. It didn’t seem like it was enough when I did it but it worked!!
Woodbutcher56
5:49 AM
N.W. Ohio
You may well be correct. I just ordered a new tank vent from Chainsawr . I ordered 2 I'll try again to nip just a tiny amount and keep one in tact. Is the vent designed to relieve pressure in the tank or to allow air in to prevent a vapor lock?
