Cheap scored 357XP
Jazzlesaurus
9:11 AM
Western MA
Recently met up with someone to buy a clean looking translucent tank 357xp. Some fading but no exterior damage. We agreed on a few hundo, saw ran great, I said let me just pull the muffler before we shake.
Piston is scored, cylinder has some transfer on the backside, and I noticed it has transfer caps as well. Previous owner bought the saw and ran it until he bought a 572 and just didn’t want it anymore.
I offered him $50 and he took it.
Before I tear into this thing, it’s got transfer caps so it’s a 359 jug, right? If so, is there any value in trying to clean up and do a my first DIY port job with this, or go straight for a 357 aftermarket setup to keep this saw dirt cheap?
Otherwise has a new OEM carb, and cleaned up decent with a forester pro bar and a new stihl chain.
Thanks to those with more teardown experience than I!
Member
8:11 AM
You could do either, if it cleans up and a new Meteor or Duke's piston is about as cheap as you can get.
I put a Meteor 357 top on a 359 bottom end and just tightened tidied things up a little bit, didn't port and it runs fairly well.
Jazzlesaurus
9:11 AM
Western MA
Appreciate that. Given what I paid I’m just looking for a decent runner, nothing wild but I would like to try a little diy porting.
Have you tried the opposite, 357 bottom end with a 359 top?
cuinrearview
Handy dood
9:11 AM
Dowling, MI
What's the bottom end? Stuffers or no? Do you know why it's scored? Bad gas? Air leak? Will you be splitting the case? All, some, or most of these answers may shape your decision. Also, before you start more threads and/or ask more questions, take a look at some of the info that already exists on this site:
Member
8:11 AM
Yes, just happened to have. I probably still prefer it the other way around, but it ain't terrible bad by any means.
Jazzlesaurus
9:11 AM
Western MA
It’s got stuffers, I have a lot to learn admittedly but I hadn’t seen many posts where folks had a 359 topend on a 357 which is what gave me pause. Some folks have given me solid things to think about as I tear it down.
I believe the saw was straight gassed, piston was bone dry, wear on the exhaust side. Not planning to split the case if I don’t have to.
Member
8:11 AM
For quite some time the true 359 top end was no longer offered for sale, hence when you ordered a top end from Husqvarna, you received a 357 top end. This led to many 359's being "converted" stock and not. It did work out quite well and was one of my favorites to build.
Fast forward to today, with both saws no longer being supported, leaves us with building a saw with what we have, which is the reason I built one for a gentleman, in the end it came down to parts logistics that still made a viable saw.
hacskaroly
2100 Fanclub Member
6:11 AM
Northern Idaho, Ehh
In my experience, this is not how straight gassed usually presents. There is usually light transfer all the way around.
I was going to say the same thing, when I have seen only wear on the exhaust side, it is from firing the saw up cold and getting on it right away and not letting the piston and cylinder warm up first before digging in. Straight gassing ends up overheating all of the sides of the piston.
Duane(Pa)
It's the chain...
9:11 AM
Centre County
Don’t waste your time trying to clean up an aftermarket cylinder. Just not worth it for what you can buy a new one for. If it was an oem 357 cylinder, that would be a different story.
Junk Meister
8:11 AM
Nebraska
I read to post #16. Is the cylinder OEM? If so vac & press test Then pull cyl and see if it will clean up. If yes do a meteor or Dukes If it is trash then go back to the drawing board. But regardless the reason for the transferring/scoring needs fixed to prevent a repeat episode.
Junk Meister
8:11 AM
Nebraska
I never saw where it IS NOT OEM -I miss a lot- just that t it had transfers on a 357.
foresterntree
6:11 AM
California
Haven’t seen it mentioned yet, but if it has the plastic intake clamp, that could have been a contributor to the failure. Delete the decomp, too, if it was there - you’re not going to have enough compression to need it…
old guy
Love me some Husqvarna
8:11 AM
Becker Minnesota
Early this year I put together a 359 cyl. on a 357 bottom, I inquired here about porting #s and stuff and pretty much followed advice. Now I am no way any kind of hot dog saw porter, but apparently I hit all the right spots, cuz this thing came out very strong.
