Chaps Work Too
Rogee
8:04 PM
New Zealand
I also found the Labonville chaps a bit stiff. I find the STIHL chaps to be pretty comfortable, although, there is always a personal fit issue.
If you are willing to spend a bit more, the Clogger pants and chaps are surprisingly comfortable to wear. Like: 'Are these really going to protect me?' comfortable. They went out of their way to design thin, light protective fabrics, instead of using less expensive, bulkier materials. They carry US and EU certifications:
https://opeforum.com/threads/clogger-chainsaw-chaps-evaluation.20077/
https://opeforum.com/threads/clogger-zero-pants.21442/
Philbert
I can vouch for the cloggers. I never use anything else these days
5155
4:04 AM
pa
I figure I cheated the odds way too long.
Bought husky chaps at TSC, black, 75 bucks.
They seem to fit ok.
I normally where Weinbrenner military steel toe boots.
If, there were a product that laced into the boots to protect between steel toe and bottom of chaps,,,,
New gloves are next.
Be aware and stay sharp guys.
I did get a minor cut from a diamond concrete saw once,
wakes you right up.
Philbert
Chainsaw Enthusiast
3:04 AM
East Dakota
A few options:
- chainsaw protective boots will have chaps-like protective material up to the tops of the boots.
- 'metatarsal' work boots include a protective tongue up the front of the boots, in addition to a steel/protective toe: these are often required in steel mills, etc.
- there are also strap-on metatarsal guards that fit over work boots and shoes, but some of these can be a little clunky.
- sizing the length of your chaps to fit low over your boots would help. My Clogger Zero protective pants have a small hook at the bottom, which engages into the boot laces, to help hold them in place https://opeforum.com/threads/clogger-zero-pants.21442/
- chainsaw protective spats and gaiters are available (Google search those terms). I have not tried any, and cannot comment on them.
Philbert
stretch5881
3:04 AM
Hatley, Wisconsin
Wear whatever brand or type you want. Something is better than nothing. 3 weeks ago up here, a fellow cut his leg just below the groin. He will not get a second chance.
Strange thing though, I see fire and ambulance members cutting trees without any ppe.
Labonville for me because they were the only ones that had the length that I needed.
magicrat
3:04 AM
San Antonio tx
I use safety glasses all the time and break out the chaps if I’m going to cut more than a couple pieces of wood. Over any period of time it’s to easy to become complacent or forget about ur bar location for just a second.
FergusonTO35
4:04 AM
Boonesborough, KY
Yikes! Speaking of chaps, doesn't someone make shin guards for weed eater use? I've seen lawn guys using them but don't know if it is a factory product or something they cobbled together.
Philbert
Chainsaw Enthusiast
3:04 AM
East Dakota
‘Trimmer Chaps’ are sold by a number of places. Some look deceptively similar to chainsaw chaps, but they do not provide the same protection.
Philbert
davidwyby
Rural desert logging
1:04 AM
Extreme Southeast CA
I was exhausted and the 32” bar 288 is heavy. Tight spot cleaning limbs to fell. I have birdlegs like @Mastermind so it probably would have pulled a chip off the bone. Chain was pretty well slowed down though. Would have had to patch it up and finish wedging/cutting the tree.
Woodslasher
Teh debil
1:04 AM
Commiefornia
Saw chaps work good, or double-knee Carhartts. I used to wear the saw chaps but I hate the heat so I switched to double-front jeans, now I just wear single-front Carhartts when I weedeat.
TheWizard
9:04 AM
Wales UK
its so easy to think "i'll only cut a few" but thats the very time youll get hit, a split second and its over. I tried chaps but find them awkward so always wear trousers with either full all around protection or lately been using just front protection which is a bit lighter but wouldnt cut without them, you have to be sensible but sadly some learn the hard way.
FergusonTO35
4:04 AM
Boonesborough, KY
Got my Powercare chaps, which is actually HD house brand. They are about what I expected. Bulky and don't fit particularly well, but they cover most of the legs. Easy to get on/off and adjustable straps too. Biggest thing I don't like is that there is gap in coverage of about five inches down from the top of the waistband. There is just plain nylon there, no protective material. Also, no crotch coverage although expensive chaps usually don't protect there either. But for thirty bux delivered I can't complain, its more protection than I had before which was just pants material.
Philbert
Chainsaw Enthusiast
3:04 AM
East Dakota
Most chaps have a plain nylon or polyester area up near the waist band. This area can often be rolled with the belt, to slightly adjust the length of the chaps.
Protection is primarily for the lower legs and thighs. Even pants do not have protective material near the crotch, as it would make them uncomfortable, and difficult to work.
If you decide to upgrade to better chaps later on, you can keep these as a spare pair, for anybody that is working with you.
Philbert
mainer_in_ak
12:04 AM
Interior Alaska
A wittle tiny knick in yer orange yoga pants. I got ah couple too.
BUT, theres a time to cry. For example:
