Changing impules on Husqvarna 50
Jim Comer
8:38 PM
Arkansas
I would like to know how to change impulse on husqvarna 50 thanks
benjpi
OPE Member
9:38 PM
Southern Vermont
The description in the link of the impulse grommet being "finicky' are spot-on. My recommendation is to order two (expensive little buggers) and expect one might get damaged during reassembly. I would second the recommendation for a vacuum test when you're done. And as mentioned in that original thread too, be careful not to strip the divider / carb mount plate. If the saw was pre-owned, the holes might already be stripped.
