Chainsaw Starter Rope Hard to Pull After Multi-Month Vacation
hotajax
1:51 AM
Eastern PA
This question applies to an Echo and a Stihl 021 saw. If the saw has been sitting for a few mos, it is very hard to pull the rope. Sometimes I have to set it down, step on it, and have the kid pull the cord until I can pull out the rope all the way. Once the cord comes out and retracts easily, usually there's no problem getting it to run Anyone have any insights into why this happens? I'm using 50:1 mix. Thanks for the help.
Woodwackr
11:51 PM
ID
I try to turn all my unused saws over every now and then to prevent this. Good to get a little lube cycled every now and then. Saws that get stored for long periods get a little mix oil in the plug hole and cord pulled several times. Then I periodically pull cords during the year.
19 runners…takes some time 🤣
IffykidMn
12:51 AM
Minnesota
Is it possible the fuel tank is pressurizing and forcing unburned fuel into the cylinder, fuel evaporates leaving the cylinder full of oil?
hacskaroly
2100 Fanclub Member
10:51 PM
Northern Idaho, Ehh
You can always take the spark plug out, give it a quick shot of WD-40, put the plug back in and let it sit for a few minutes giving it a chance for the WD-40 to seep down the side and then try to turn it over and see if that helps.
7:51 AM
Curious how no one asked! :thinking:
What 2-Stroke oil are You using in Your fuel mix?
Any chance the oil is gumming up?
Just a thought as I newer encountered issues like the one You described and I own 27 running saws plus several weed whackers, and a tiller, and a mover, and an auger - all 2-Stroke.
Good luck.
Cheers
hotajax
1:51 AM
Eastern PA
Good luck.
Cheers
Thanks Wilhelm. Using VP Fuels Full Synthetic oil at 50:1 and E-Free gasoline. Seems like it only happens with the chainsaws, and not with my trimmer, lawnboy, or hedge clipper. Just the saws.
