chainsaw hot tub
Definitive Dave
Piss Rev Mafia Member
1:00 PM
Central Ohio
yep I gave away my harbor freight ultrasonic at the NY GTG and the 27 litre arrived today, it heats up quicker than the 10 liter and has a much nicer timer.
they look the same but you can set the time much faster, on the small one you have to press the button once for each minute of time you add so it is slow
If I remove the top handle I can submerge an entire MS660 in the bathtub :)
The old one would hold a crankcase, but doing a tank handle was a three step process.
It holds better than 5 gallons.
Definitive Dave
1:00 PM
Central Ohio
Word to the wise, don't soak metal badge covers in a hot US cleaner with purple power. Washes the badge right down to clean metal.
What a drag that was learning.
I did a top cover for the red light that had a completely rashes out badge and it cleaned it nicely and left a matte grey finish.
But absolutely don't put a nice badge in there with heat and make sure the cleaner doesn't react with them either.
I will change the f'luids when they look dirty, I don't have a filter setup but am not planning to use anything to harsh as far as cleaners or too expensive, so it is easy and cheap to swap out
Mike (glock37) told me to use a heavy packing tape to seal the edge of the electronics on the front cover in case of spills or sloshing - a great tip to protect te brains of the operation
Magic_Man
Oh Yea !
1:00 PM
SE Ohio
A very wise tip, I have Randy's old one in my shop and that looks to be what took out the main board in the bottom. Be careful with water on these, not much protection in there.
Canadian farm boy
“Normal” people scare me.
1:00 PM
Ontario, Canada
I know it's been asked before in another thread but I can't find it.
What would you guys suggest using in a ultra sonic cleaner?
I was thinking something like purple power, simple green or maybe awesome.
I was also thinking about trying seafoam.
idiotwithasaw
12:00 PM
Ky
Where would one get a new circuit board for one.
Definitive Dave
1:00 PM
Central Ohio
I would check with an amazon seller to see if they can get one, or a seller on Ebay.
