- 4:04 PM
- Feb 4, 2017
- Winona County, MN
Interesting to hear your experiences. I use Mystik everyday in all my saws. Oilers turned to Max setting. None of my saws leak it, and I always have bar oil left in my tank when it’s time to fuel up. I also don’t experience any unusual wear or high heat. My chains rarely sag and I can always grab the bar…I bought 5 gallons of Mystic when it was on sale in late fall and that stuff is like water. Zero tack.I can't run my oiler wide open as it just drinks the thin stuff compared to the TSC I was running. I ran my 346 for a couple minutes after I replaced the sprocket nose on my Tsumura bar and I literally had bar oil running off the top of the bar right near where the oil is injected. It was dripping all over the floor and everything. I'm used to the old TSC stuff, it was thick and poured out like molasses when cold and very stringy. I guess TSC has recently changed suppliers though and the new stuff is also like water and zero tack. So I've been looking for a good replacement for the older TSC stuff that I really liked. I bite the bullet and ordered some AMSOIL, as that's supposed to be very tacky, but at $25 a gallon it's not cheap.
So I'm going to be giving away the Mystic I have. It's useless to me. May work better in saws with weaker oilers. Yes I can turn my oilers down, but the lack of tack concerns me. I know some people use motor oil and they seem happy with it. Motor oil is probably pretty similar to the Mystic I have. The way I see it, there is a reason why they add tackifiers to bar oil.....or at least are supposed to anyway.
Almost sounds to me like you have an issue with your saws if it’s leaking out all over.
