pbillyi69
- 11:03 PM
- Feb 21, 2019
- USA
Ok so here we go, I have built from the case up a jonsered cs2188/390xp it has all new oem everything except for the fly wheel and coil. it pressure/vac tests fine but the H needle has little or no effect on it. it starts and idles just fine and it runs fine two i ran a couple of tanks of gas through it and decided to tune it a little more as i figured it was probably a good time to check it out. i cant get it to rev higher than around 9500 rpm. i can turn the H needle out and make it run super crappy but can turn it all the way in until it seats and not lean it out at all. What to check now? The carb is a brand new non epa oem carb. i didnt pressure test it or check the metering height as it is brand new.
