slackinoff
- 12:53 PM
- Nov 24, 2021
- usa
Wow nice work!!
Right now, epoxy and those tiny screws. Future designs will probably at least have islands un-milled or rivets in the ends.Looks good for sure! How are you holding the carbon fiber in the bar?
Are the bar's without any insert too weak to use?Probably will not be the final design of the bar, but I added some tiny screws in the ends of the panels to help retain the ends.
The insets on the Oregons had a tendency to come loose in the middle where they are glued. I’d fix them by riveting them in the middle.Right now, epoxy and those tiny screws. Future designs will probably at least have islands un-milled or rivets in the ends.
They would be kinda flimsy and chips would get stuck.Are the bar's without any insert too weak to use?
Could the same area that you cut out simply be ground down on each side to reduce weight and hold rigidity?
Maybe leaving a vertical full thickness section to act as a brace in the middle.
One of the guy's on here used to have a big dolmar with a skeletonized barThey would be kinda flimsy and chips would get stuck.
Just wondering if ran a small T - cutter at bottom around perimeter into side wall like .05-.075 , to provide a lip for the carbon fiber to hold on to , just a thought ?
I think @SOS Ridgerider didn't have as much trouble because he did two sections of CF that could move independently and not pull so much, but I think this makes the bar less rigid.
Yes. The epoxy is just there so the pockets don't fill with chips. CF with full pockets will be stiffer and lighter if I can get it down. Another option would be to make the pockets larger and fill with CF, which would be lighter, but not sure it would be any stiffer, and less durable.I think this consideration is why you see many lightweight bars (e.g. Tsumura) using several small staggered ovals in their design. It spreads the twisting stress out so no one piece is affected so greatly that it separates from the bar. Staggering them minimizes the lost rigidity.
Effectively they're trading off some amount of rigidity for increased durability.
Just my guess.
Edit: to add image of example
How many bars do you think you will get done with that? Can't wait to see these in action$550 worth of different CF remnants for testing. Gonna have a few 32” .063” bars to sell/test.
