carb alternative
Mathewsdxt75
Learning OPE member.
7:58 PM
wisconsin
I have an Echo CS 302s that has a walbro wa 5 on it. I can't for the life of me get it right. Does anyone have any idea what alternative carb would mount up correctly on this saw? Finding a used one isn't easy.
Chainsaw Jim
Con Artist LLC
5:58 PM
Springfield Oregon
I think some of those are about 2-3 turns out on the high.
Most WA carbs should work and you can swap out the shafts if you don't find the right one.
Mathewsdxt75
7:58 PM
wisconsin
Ok thanks. I will start with double checking everything else. I will need to pressure check it too.
the saw idles ok. And once in awhile it will rev just fine, but most of the time it falls flat.
