Can I use a 288xp crankshaft in a late model 395xp?
markds2
12:36 AM
Nelson, New Zealand
I have just picked up a 2015 395 with a toasted big end bearing. Can I put a 288xp crank in? They look dimensionally the same.
qurotro
Cookie Cutter
7:36 AM
Ar
Flywheel key is different, 288 and 394 use keys and 395 use cast in key on flywheel
I'm interested in this. Can you just remove the 288 crank key so the 395's cast-in-key flywheel can bolt on?
8:36 AM
You can just run a 394 flywheel with the 288 crank on the 395. Same crank on 288 and 394. I think the flywheels themselves might be different, but I’m not sure.
Nutball
7:36 AM
Mt. Juliet, TN
Could you grind on the 395 flywheel to accept a 288 key?
markds2
12:36 AM
Nelson, New Zealand
Well gentlemen, you raised some interesting questions in my mind so I went and had a closer look. 288 and 395 cranks are totally different. Different key slots, tapers and flywheel nut threads.
Here's the 395 (which I picked up for approx $390usd) totalled crank and piston. Cylinder is still great:
Removed the flywheel:
And I find that the crank I thought was from a 288 is actually from a 395! Here is a 288 crank and 395 side by side:
As you can see the taper on the 288 is wider and at not as an acute angle.
Mattyo
Youtube speciawist
8:36 AM
Farmington, CT
288 394 crank are same thing.
394 crank and flywheel fit in 394/5 crankcase. 394 fly wheel is not compatible with the 395 crank...and vice versa.
288 flywheel not compatible with 394/5 case
Mattyo
Youtube speciawist
8:36 AM
Farmington, CT
I ordered 2 of those flywheels..... 394 flywheels are nla and relatively unobtanium. Nice link.
dustinwilt68
Wilt Built Work Saws
8:36 AM
Southwest PA
How many cranks and flywheels you need for the 394s?? Them things never go bad unless they are ran over or something.
Mattyo
Youtube speciawist
8:36 AM
Farmington, CT
Uh....me want them all!
Sorry....had to quote cookie monster.
Funny how that's relevant lol
dustinwilt68
8:36 AM
Southwest PA
You know me Matt I try and keep 8-10 extra 394 cylinders/cranks and such in stock all the time.
srcarr52
8:36 AM
Iowa City
The taper may be different. I’m not certain. @srcarr52 will know
Being that the 395 taper is smaller than the 394/288 and the cast in key without a steel hub is weak, I've found they have a tendency to slip when you have a saw that will accelerate really fast. I have cut in a 288/394 style key into a 395 crank/flywheel before, it's not super easy but can be done by hand if you have the patience.
To combat the flywheel slipping on a 395. I heat the flywheel up before installing then I hand tighten the nut as far as I can with a plastic piston stop in the squishband. Then beat on a socket over the flywheel nut and re-tighten. Repeat until you can't turn the nut anymore after the beating!
