Never had one of theses saws in my hands, so obviously I'm just spitballing some thoughts.
I tend to still think and get ideas like I'm in a machine shop, even though I'm not anymore. (wahhh)
Has anyone tried hanging an extra solenoid as a dummy for the ignition?
Of course you'd need a way to get fuel to flow to run the engine.
A bit of something to hang the solenoid open that's still on the carb body
or just mount a non auto-tronic carb (if all that is practical)
After doing all of that....
Would the ignition get confused when it's attempts to adjust the saw RPM didn't get the expected results?
What would the module do?
Go into a "limp home" mode or just do the aforementioned brief run and shut off routine?
Heck. If the ignition would stay happy and run while hooked to a non installed solenoid...
Could someone make a "cartridge" with an adjusting screw (blunt or flat end?) to fit into the carb body where the solenoid normally fits?
Think a little bit like the old screw and bolt that held the float bowl on an older mower engine.
A Screw in the middle, but with an appropriate shaped end so as to fit the need.
Maybe the cartridge has a drilled passage and the screw works against an internal surface, thus controlling the flow through the cartridge and the carb circuit?
Or does the ignition feedback cover enough operating range that the carb lacks the old type of mid-range fuel circuitry, due to the processor, also, altering the fuel flow at speeds less than max rpm?
In other words, would it meter fuel worth a heck if you somehow popped a (properly sized)
metering orifice into the solenoid hole, to (mostly)cover max rpm in a fashion of the old screw carbs.
Is there even room, physically, to do such a thing?
Are the all of parts and saw body, air box, etc arranged in such a way as to permit it?
