Broken piston crown (Echo CS-7310p)
bwalker
10:02 AM
Montana
Same customer, different saw (620 instead of 7310). This is the 3rd time this saw has had this exact failure, which I blame on overspeeding. I put a 590 single ring piston in it so hopefully the ring lands are stronger.
Lots of oil, but the piston got toasty at some point.
View attachment 482615View attachment 482616View attachment 482617
Ring gap too tight. Piston appears not to be ran too hot or it would show "death ash" beneath the crown, which it doesnt have.
legdelimber
10:02 AM
N.C.
I've seen some Echo blowers pb-403 pb-413 and pb-620's , that the exhaust port was nearly flat on top. High hour landscaper units. Machine marks worn off of the pistons and the cylinder plating looking thin in places, in the couple that I pulled the cylinder.
At idle, the rings sounded like a spoon player.
I was truly surprised that the pistons tops or rings hadn't been broken on the exhaust port.
Guy said that he had never run anything but Echo Power Blend oil in them.
No idea of the ratio.
EFSM
9:02 AM
Extreme southern IL
There is no scoring, which should happen during a case of the ring being tight. Also, a tight ring gap would show up before a year of hard use. I actually don’t even bother checking the ring gap on Echo pistons anymore because I haven’t ever found one that needed adjustment.
