There's small parts you can use - like the fulcrum (goes from the brake handle to the brake band), the lever and the lever spring (these parts go under the fulcrum), and the e-clips.
You cannot interchange the brake handles, brake bands, or the tension spring (brake return spring).
If the ones you have don’t work, I’m sure I have the 064 parts here Tom.
Pretty sure the little lever part that attaches to the small spring are all marked 1121, just like almost every chain adjuster I’ve seen is marked 1125.
