Big bore/stroke 372
12:22 AM
Canadiancarguy did it many years ago that's the first one I remember.
Ketchup
Epoxy member
10:22 PM
Colorado
IIRC, there were crank failures using a 372 crank and some case failures if swapping to a larger crank. I think there are a few threads over on AS about it.
KingCobra98
11:22 PM
I think he is also using Farmertec cases.. That should be interesting to see how long those last.
jacob j.
Only the weird
9:22 PM
Coastal Oregon
Is he changing out the crank bearings? Those are the weak link in Farmertec cases of all flavors.
KingCobra98
11:22 PM
not sure. I really wasn't paying to much attention to it. I know he's using Farmertec tank and cases. The crank is a used OEM with a 390 cylinder bored to a 58mm I think??? I think the piston is a stihl 661, but I could be wrong.
pwheel
Finis Origine Pendet
12:22 AM
MA
Not sure that the 372 bottom end was engineered to handle the extra loads of a big bore mod long-term. We'll see...
KingCobra98
11:22 PM
That and Chinese material...
farminkarman
I like the red & black ones
11:22 PM
Neenah Wisconsin
The 372 bottom end can't even handle slinging an x-torq piston around. IMO, if a good ported XP oe top end isn't enough, then a bigger saw should be considered.
jacob j.
Only the weird
9:22 PM
Coastal Oregon
I forgot
It's been year's since I seen him post anything.
He's been out of the game for quite a few years. Someone told me he's running heavy equipment now but I didn't verify that.
