- 6:12 AM
- Jan 24, 2018
- Extreme Southeast CA
Canadiancarguy did it many years ago that's the first one I remember.
I think he is also using Farmertec cases.. That should be interesting to see how long those last.
Is he changing out the crank bearings? Those are the weak link in Farmertec cases of all flavors.
Not sure that the 372 bottom end was engineered to handle the extra loads of a big bore mod long-term. We'll see...
The 372 bottom end can't even handle slinging an x-torq piston around. IMO, if a good ported XP oe top end isn't enough, then a bigger saw should be considered.Not sure that the 372 bottom end was engineered to handle the extra loads of a big bore mod long-term. We'll see...
I forgotI think Daniel's was a 385 top end on a 372 chassis. He had some wild and good ideas.
I forgot
It's been year's since I seen him post anything.
58mm bored and sleeved 390 cylinder 661 wiseco big bore
Stroked 372 crank
Is the parts list for the big one.
