Best way to loose comperssion? 064
lwhaples
9:33 PM
Vt
D handle.jpg AM not so good. The saw is a 064 with a 066 jug. I cut the squish band .030 and cut the base to get .020 squish without a gasket. I've had it running and what a beast,took awhile to get it to tune. Today I wanted to mess around with different a carb. Guess I'm not man enough to get it to run again, reset the timing back to stock then added a D-handle.Not going to happen the way it is. So, put a gasket of some sort in or cut the exhaust to loose some compression?
I didn't write down the the numbers,but I want to say 99 120+ and 78. Something like that, felt it was good enough as is to run as a base line. Thoughts?
Redbull661
661 hoarder (BlueBallz)
8:33 PM
MN
cease232
9:33 PM
Montana
Are you sure it's not flooding. I can pull over a 90cc saw with over 200# but a similar saw with 165# gets a little fuel in the cylinder and I damn near rip my hand off.
lwhaples
9:33 PM
Vt
Not flooding. My right arm isn't the best. My other 064 ,I can start. This one is just mean.
doesnt it have a decomp valve
No
lwhaples
9:33 PM
Vt
Will it kick like that on the first pull after sitting for a few days? The pop off might be just low enough to let too much fuel in but not flood.
Once it gets fuel,it pops on every slight pull and rips the cord out of my hand .That's why I put the D handle on.But that only destroyed the recoil. Plug never looks wet like it's flooded. Tomorrow might be the happy day.
Cutforfun
6:33 PM
Palmer mill
Sounds like timing is off, I had a two slot flywheel that if I put on wrong would do the same thing.
9:33 PM
I got an 064/066 hybrid here aka "The Unicorn" that will rip the cord right out of my hand if I don't pull it like I mean it. Get some fuel in it and you're SOL. And that's with under 200 psi.
I'd say you have to check compression before you do a single other thing. Seat of pants compression feeling means nothing. If you're really at 180 psi, you're gonna look for other reasons starting is hard and leave it alone.
If you have to lower compression, the proper way would be to put the jug on the lathe and open the edge of the band/chamber interface upwards at an angle. So basically cut up into the chamber at like a 60* angle to make the chamber larger.
Opening squish is easier but not the right way.
Deets066
AKA Deetsey
9:33 PM
This
lwhaples
9:33 PM
Vt
Something I will check.It is the dual slot flywheel. It was popping before, that's why I set it back to stock.Still may be in the wrong setting.
lwhaples
9:33 PM
Vt
Can you pull it over with the saw in the off position?
This saw is a bit rugged on my arm and shoulder. When I do the compression test,that will tell me.
lwhaples
9:33 PM
Vt
This is kinda what I was looking for.Need to figure out how to make that type of cut with my lathe.
Agreed!
