B&BLogging
Upside down logger
- 7:58 AM
- Jan 10, 2016
- Connecticut
So I'm sure that I'm going to get various replies about all different types of chain. Everyone has their own opinions on which saw chain is the best, and those opinions are exactly what I want to hear. Lately I've been going through too many chains, it's the Oregon full chisel lgx chain, 3/8 .50 gauge, the "new, so called, x-grind" stuff. I know full chisel isn't really meant for dirty wood but I've never had this much trouble with a full chisel chain in the landing. It's not due to hitting the ground either, although I'll admit, chit happens, I think it's just from the slight dirt on the logs from skidding. Usually I have a dedicated saw that just stays in the landing so that's why I am looking for a chain just for landing use, something that works good in dirty conditions, bucking logs and something that holds a good edge between sharpening and also requires less of it. Also the chain I'm using now seems harder to file for some reason and the cutter wears down to nothing unusually quick. Has anyone experienced that also? Would a semi skip chain be better? Maybe I should use semi chisel in the landing? What do you all recommend?
Thanks in advance guys.
