flyin'chips
Active OPE Member
- 9:43 AM
- Jul 29, 2020
- Between piston and cylinder
Hi,
I'm looking at replacing both the cylinder and piston in my 371xp. A piece of broken ball retainer from bearing got jammed between the piston top and decomp valve hole and caused a 5 mm long and 1 mm deep, 1 mm wide groove in the cylinder. It's short but still will probably ruin the compression. A shame as otherwise the original cylinder is in good shape.
So would a Meteor Cylinder and Piston kit be the best option? The saw is not gonna be ported but I would like to get as close to stock performance as possible. OEM price is astronomical and it has turned out this saw has had a very rough life.
