Bar to run 10 pin???
redoakneck
7:02 AM
Ohio326
I have just acquired a 10 pin, .325, and 10 pin, .375 rim sprockets.
What type of bar would one desire??
Need a wide tail and large sprocket nose I assume??
Looking for something in the 16-20" range.
Stihl mount, so I can use on husky too.
I have a large mount 20" husky cannon in .325 pitch, but it had a narrow nose, which I think is bad at high chain speed.
By the way, this is all definite Dave's fault!!!!
T.Roller
7:02 AM
Southeast, TN
Bob your bar, redrill your tensioner holes in the bar, and your oiler hole. I run a 10 pin 3/8 like this
redoakneck
7:02 AM
Ohio326
Bob the bar??, Cut the tail down??
Got any pics???
Hope yer not getting any of that flooding I'm seeing on the news!!!
No plug and play available???
redoakneck
7:02 AM
Ohio326
Just checked out the other thread, I think I have a good idea what to do now
As far as the tip I'm assuming wider is better
Chainsaw Jim
Con Artist LLC
4:02 AM
Springfield Oregon
You probably won't need to modify your bar with the .325 sprocket. You'll just need to add a link to the chain.
I think the .325 10 pin is the same size as a 3/8 9 pin so all modifications actually would be necessary.
redoakneck
7:02 AM
Ohio326
Any opinions on the bar nose size???
Ok to run a super mini tip??
Seems a wider nose would give a better transition
Definitive Dave
Piss Rev Mafia Member
7:02 AM
Central Ohio
I haven't seen guys with oversize sprockets use mini tips.
you need a tail that is wider and I think you would have a hard time finding a fat tail small tip bar
I guess in theory it like a bicycle with a big powerhead gear and a small working end gear it should spin the tip very fast but you don't just cut with the tip on a chainsaw
I think it would be more likely to throw a chain on a narrow tip
all just my thoughts which aren't facts by any means
Dave
T.Roller
7:02 AM
Southeast, TN
Dave
+1 the bar I use is a regular weight Sugi Hara
