Clarkbug
- 11:18 AM
- Sep 19, 2022
- Northeast
Good afternoon all
Working on a snowblower for a friend. He got it from a family member, and it doesn't like to run unless partially choked. I took it apart and found the purge line ripped and the main jet was plugged up. My guess is it was sucking air in through the ripped tube and generally just sat with some lousy gas.
Anyway, I want to button it back up, but need a new o-ring between the bowl and top, Want to avoid buying a whole kit if I can just get that ring.
Also hoping to get a diagram of how everything is supposed to go together. Someone else has been in here before me, and I think a gasket or two is missing or parts were in the wrong order. Also don't know if there are supposed to be any other o-rings on any jets or tubes inside.
This has the AX engine on it, which looks like an Ariens special made by LCI for them as a Tecumseh clone?
Appreciate any info you can offer up!
