TheSnake
OPE Member
- 11:54 AM
- Dec 24, 2015
- Port Beach, FL
Are thes bolt supposed to be self-tapping?
OK well tey are pretty common saws down here.Nope none of us have ever worked on one of those...
Some of the Chinese cylinders don't come pre-taped so you have to do it yourself... I chase the threads on all the 029/390/039/310/290 cylinders with the correct tap whether they come threaded or not.The bolts install from the bottom on this saw. The cylinder itself is tapped.
Sent from my VS980 4G using Tapatalk
That's why I pre-tap... Yes the bolts are self tapping but cutting the treads in first will help direct the bolts when you assemble. Also it removes any chance that the self taping bolts run sideways or heaven forbid breaks off one of the cylinder ears.The cyl bolts are self tapping. Use the case spacers or washers to mock up the jug and crank cover to let sealant set up over night then take the bolts out and install in the case.
LOL I had one brake off in a damn ms250 hutzl engine a few weeks ago man was I pissed!!!!... damn near took it out back and shot the damn thing.....believe it or not they sent me a new cylinder without any hassle!!!Almost forgot....BE CAREFUL OF THE GROUND WIRE SCREW THAT GOES INTO THE CYLINDER!!!!
Most of the AM cylinders are drilled and taped for the ground wire but 85% if them are not deep enough for the OEM screw! You'll end up wanting to over tighten the screw and it will brake off causing you more headaches than you already have.
Welcome to OPE...
That's why I pre-tap... .
I don't know about you Makita guys.Nope none of us have ever worked on one of those...
