Anyone converted an 026 to run picco super?
skip sail
3:21 PM
Victoria Australia
I've got a spare 026 on the shelf,and I'm wondering what it would be like running the Picco super chain on a 16 inch bar.
I'm not sure if this conversion is possible,due to bar mount size,but if anyone has some pointers or experience with this,please chime in.
Canadian farm boy
“Normal” people scare me.
1:21 AM
Ontario, Canada
These cuts weren't timed but I think you can get a pretty good idea of the difference. I'm not sure if the first saw is ported. It's running .325. The second saw is ported and is running picco
CR888
3:21 PM
Australia
You can buy the kit here too as mentioned...its about $100 & decent value for a dealer here considering what it would cost seperately in total. Me, I just pull the bar sprocket of a standard 3/8 bar & grind it down with a chain grinder to match the profile of a picco nose sprocket. But on my ported ms261 or stock 550xp I find they want more chain in the hardwood I cut, but if I was on the other side of the globe I would see the situation differently I'm sure. What works well here does not neccessarliy work well in the U.S & vice versa. But give it a go....I did.
1:21 AM
you guys are gonna make me go buy one of those kits huh ?
Canadian farm boy
1:21 AM
Ontario, Canada
When I bought my kit it was $109 CDN. After all the taxes. I paid $125CDN out the door. Well worth it IMO.
I believe cannon also sells a picco bar that fits the 026 but IIRC it's only available in 18". You would still have to get chains and a sprocket.
skip sail
3:21 PM
Victoria Australia
great info fellas,thanks.
Will be ringing the dealer today to see if they can get me a kit
my 241cm is an angry termite with PS chain on it,and gets more of a workout than any of my bigger saws,so i cant wait to rig up the 026
skip sail
3:21 PM
Victoria Australia
Ouch! just looked the kit up at the local Stihl (pronounced steal) dealer.
$232 Aus !!!!!!
Locust Cutter
Air Force Redneck
12:21 AM
KS
It would be interesting to see some 346, 550 and MS261 vids with 3/8", .325" and Picco. I think for the cutting I'm doing a shade less speed and a tougher working corner is where it's at, but I'm always down for scientific experimentation (not at my expense)... I ain't got the $$$ to piss away on it.
Chainsaw Jim
Con Artist LLC
10:21 PM
Springfield Oregon
You can run picco on a regular 3/8 pitch bar tip but you usually need to take a file to each side of the sprocket teeth just enough to fit between the straps and settle for a smooth ride. Some bar tips with enough wear are already thin enough.
94BULLITT
1:21 AM
VA
I have a picco setup on my 026. The saw is bone stock. I have ran it with the 7t and 8t sprockets. It could use a tad more power with the 8t. My 261 is nasty with the picco b/c and 8t sprocket.
