Stihlmar
- 5:02 AM
- Oct 26, 2017
- Tipton, IA
I’m a firm believer that Nothing runs like a Deere. I’ll check it out. Thanks
The Eagle Eye has landed. Good eyeLooks like a "burr" was left after cutting.
Need to make sure you scrape that out good.
How much smaller is your mandrel than the bore size?![]()
Double check the port bevels while ya at it.And make sure there's an arch on the ex roof and floor for the rings to get tucked in
I run 40:1 in my stuffs.Aside from any burrs or port bevels. I was talking with some old Timer tractor pulling guys and they had asked a few questions here and there about what exactly I was doing.
They had made a comment that while increasing compression is important they seems to think that there is a much needed increase in oil ratio. Increased compression makes more heat and therefore much more oil is needed.
Is this something that is typically true? Never even crossed my mind but both cylinder I have done recently have had the same issues. I usually run a 40-50:1 ratio. Thanks
More intake doesn't make it sluggish, more snappy if ya ask me. But generally a loss of torque and uses more fuelWorked on the cylinder tonight. To impatient to take pictures and it’s nothing you guys haven’t seen before. Just worse. I don’t have all the fancy tools and it’s all AM chit.
Raised tranfers and exhaust. Put jb weld in intake. Plug looks to be dang close but doesn’t hit. Hoping to get comp check and possibly proof of life tomorrow.
Exh. 100 Trans. 120. Hope to get intake to 83
A very long intake duration will cause sluggish acceleration and extra fuel usage? Is that correct?
