Another 562 Tip
Spike60
7:38 PM
Ulster County, NY
Embarrassed to say I got fooled on this 562XPG the first time around, but sometimes it's the little things that we overlook that bite us in the butt. Saw wouldn't run and it wouldn't prime. Carb not priming usually means the carb is junk, so I replaced it. Ran fine.................but the problem returned. Turns out the issue was a loose fit on the little S shaped primer line, where it attaches to the carb. Sucking air instead of sucking fuel. Probably some ethanol effect on the line, or maybe just not so good a line to begin with. This little devil is on all saws in the 550 and 562 families. The nipple on the carb is larger than the nipple on the primer, so in a pinch, you could turn the line around. This guy of course gets a new line. Just another thing to check when working on these things. :)IMG_1369.JPG
pro94lt
6:38 PM
South
Why the blue air filter base? Xpg?
Farmchuck
7:38 PM
Nepa
Hey Spike when do you generally start seeing the 2017 models?
Spike60
7:38 PM
Ulster County, NY
No definitive answer to that. Depends on when they run low on a model and schedule a production run. The later in a year they build something, the later the following year will see current year model runs. Some models sell better than others. Lot of variables.
Farmchuck
7:38 PM
Nepa
I understand. Any changes/updates you know of slated for the 562?
Thanks.:)
