exSW
'Cause Thomas is a poopyhead
- 11:03 PM
- Dec 23, 2015
- United States
My 850 First saw I ever did a nut n bolt rebuild on.
I remember when you pieced it all back together. Turned out great.
How's that old betty treating you?View attachment 81783
Super 250,'cause I wanted something that would pull that bar.
I think the build is in the s a w h a w g z archives.
If the link to the sawhawgs build is still up can you post it?
First saw I ever used. Was about 12 before I could start it, still remember staring at it for what felt like ages before I could.View attachment 81783
Absolutely. Post any links to other related sites.
Perhaps but they are easy to advance the timing with points .I've talked about my 6-10 that's cranks on at 15,500 rpm before .It has points .They are set wide which advances by maybe 3-4 degrees .Which in theory would be maybe 28-29 degrees as opposed to stock 26 degree advanceThe one Major thing that holds these older saws back in my opinion is the points. They can only take revving so high before they bounce and act like a governor of sorts. I've chipped a few Macs and some old Stihls, this being the only modification. They act like a whole new saw, a much newer saw.
No complaints. Dusted it off to put a 3/8 rim drive on it and had the wrong bearing.How's that old betty treating you?
This ain't ArboristSite, you can just type out SawHawgz here.
