All Things 288XP
10:00 PM
Finally found some Saw again had the recoil shield 8.79
If you ever need them.
I've got two on the way to finish my friends saw's.
One is a house warming gift for my friend we are building a house for
He doesn't know about the saw.
Can't wait to give it to him.
XP_Slinger
They’re Just Saws
10:00 PM
Central NY
View attachment 84873 View attachment 84874
That doesn't look like the correct shroud to me. I'll get a pic of mine to compare.
Best house warming gift ever!
10:00 PM
It was in the pileoparts don't worry I've got two new one's on the way.
That long 4mm bolt in the upper spike on the case is going to be fun to find lol
Here's a 371 bb i built him year's ago trash find it's had a rough life still runs excellent.
XP_Slinger
They’re Just Saws
10:00 PM
Central NY
You've got the right one @Czed , didn't look right too me at first. Not enough coffee yet I guess. Not sure I would like my coil wires not being supported over the top where yours is broken though.
XP_Slinger
They’re Just Saws
10:00 PM
Central NY
My flywheel screwed up again! Didn't shear the key this time, 3 consecutive fins busted off after running it for 2 tanks. I'm guessing the damage was done when it sheared the key and I didn't spot the cracks. I'm gonna put a dial indicator on my crank just to be sure there isn't some freak bend that's tearing up the flywheel.
XP_Slinger
They’re Just Saws
10:00 PM
Central NY
Swapped this sombitch out and my saw is up and running again. Also took the time to drill my cover for the decomp. Call me a heretic if you want, but I didn't like the feel of the extra tension on the starter without it. Took my time, measured several times and it came out perfect.
srcarr52
10:00 PM
Iowa City
View attachment 84930 View attachment 84932
I don't dare pull mine over without pressing the magic blue button first. The starter pulley on a 288 is a little small and doesn't give you a lot of torque.
Toad22t
9:00 PM
Central Wisconsin
The one I had ported didnt have a magic blue button. I tried drop starting it a few times and learned quickly to start it on the ground and find the compression stroke.
@mdavlee had a name for the "magic" blue button. But I'm not ashamed to say that I have to use that button to cold start the 385 that he built me.
10:00 PM
Got to put your purse down and pull. I built 2 non decomp 288s over 225 lbs. My dad and his friend thought it was locked up. I started it and give it back. My 62mm 880 still doesn't have a decomp. If I never race cold start it won't get one
Adamski
Plebus Splederns
3:00 AM
Essex, UK
Ditto on the compression stroke. My old 181 had this non decomp issue.
XP_Slinger
They’re Just Saws
10:00 PM
Central NY
But my purse matches my boots.
XP_Slinger
They’re Just Saws
10:00 PM
Central NY
Found what busted my flywheel. Noticed some thread marks on one of the busted fins, some A-hole forgot to tighten the filter elbow bolt after he swapped it out and the bolt found its way into the flywheel area. Oops:mad:
danimal
9:00 PM
Armpit of da Midwest
I hate when that happens.
went to start my 272 once and a bolt fell down n jammed flywheel to coil. I couldnt turn it over. wtf I thought. da saw locked up. Good thing it happened then instead of while running. I locktite everything on me darn huskies.. Dear Lord I luv em tho.
10:00 PM
Had a pleasant surprise on my friends saw.
Very low hour saw never been apart.
Excellent shape it's a mystery missing the handle but i have one.
Waiting on shield and seals and other small part's to arrive.
Going to rering the piston with a caber clean up the bore new line and carby kit.
20170823_193310.jpg 20170823_193255.jpg 20170823_193250.jpg 20170823_193219.jpg 20170823_193135.jpg
