Aftermarket weed eater carbs
junkman
Crush it
3:54 PM
pacific northwest
Anyone have good luck with them yet ? I have had 3 new ones that do not work right out of the box ,put a known working oem on and they run fine , wondering if anyone has had good luck with them before i try again .
models are fs 45-46 and fs80 i have tried so far
DSS
widebody
7:54 PM
canuckistan
I've got one here for an fs45 but haven't tried it.
I've never gotten a bad saw carb and I've used quite a few.
Do they sell them on the Snap On truck?
Disciple of Monkey's
5:54 PM
I recently replaced one on an Echo that had one of those little ZAMA rotary carbs with a China one, and returned it to working order. The original carburetor just would not take to a rebuild for some reason, so instead of wasting more time on it I chose to replace it and the trimmer worked great after that. So did I just get lucky?
grassguerilla
5:54 PM
St Louis ish
I've had good success overall with them. Only had one that wouldn't tune. Seller refunded my money, I was out about $3 in shipping. 1 out of 8 so far. Some have even said Zama on them. Appear to be the real deal.
Simondo
11:54 PM
UK
Mostly ok...the best rotary ones ( OEM or after market) have the tiny little slot head screw under a cover plug so you can adjust the L side..Walbro. or Zama...not all have it and its a right pain if not I find Screen Shot 2016-06-23 at 19.06.46.png
junkman
Crush it
3:54 PM
pacific northwest
well i bought a new oem stihl carb ,decided to try the aftermarket one one last time to see if it would run ,and it did ,wtf was crapping out last time i used it ,now it is working
panteliss
12:54 AM
Europe
In a machine that cost 100 or 150 its not worth to put a 60 or 70 euros oem carb , or any other oem parts
Simondo
11:54 PM
UK
That's good to know ,did not know about the hidden screw
Bit of a lottery iv found ...some have them ,some dont have a adjuster , just a brass looking ball in the hole with sealer on top. Have fitted a new adjustable rotary choke throttle body in a Echo hedge trimmer that just would not idle right . Perfect with new unit in place after adjustment of the small L screw. Oh yea..you need a watchmakers screwdriver .
Simondo
11:54 PM
UK
its something like 2.5mm screwdriver.
those cheapy pocket screwdrivers are small enough to fit if you grind off the flair above the blade
That would work ...or...as i had a few spare carb screwdrivers ..one got modded . Titchy little beggar of a screw head !
Clemsonfor
6:54 PM
Greenwood SC
Not a weedeater but I had a cheapo china saw with a Walbro carb that would not fix from a rebuild. A cheap aftermarket china carb fixed it to new.
