- 11:50 PM
- Dec 24, 2015
- Coastal Oregon
Plot thickens.![]()
I'd like a 390XP top end with a lower exhaust port and six transfer ports while I'm banging this drum.
Plot thickens.![]()
Go away trollI'm here now dot dot dot
What cylinder and port details can you share with us ?We will also have the Masterminded 066 and MS661 cylinders.
I would really like to see the process of using your jugs to cast new.
Thank you Randy !!Good questions.
I made the jugs that were sent to be cast from, so I might be able to answer some of those questions.
If the past jugs Bruce has had done are any indication, then yes, they will be nikasil plated.
They are performance replacements. They both use the stock type piston. I'm sure machine work would be needed to use any other piston.
Base thickness has not been compromised on either jug. They are plenty thick. I can tell you exact dimensions though, I just didn't check that.
I don't have my notes in front of me, but port timing numbers are mild rather than wild. I'll do my best from memory.
I cut .040" from the squish band on both jugs. On the 660 jug I used epoxy to lower the roof of the exhaust to 100° Transfers at 118° and intake at 81°. It should make a good runner without too much compression. I expect it to blow 200 - 210. It will use a factory base gasket.
On the 661, I used epoxy to raise the floor of the intake. After cutting .040 from the squish the ex is at 99 - 98. Transfers at 120°, and the intake at 80°
I didn't want these jugs to be over the top. I was looking for a good gain, with longevity in mind. Lots of room to go further......
