A pair of 50 cc saws all set up
Blackgreyhounds
10:29 AM
S. Central PA
I finally got bars, chains and sprockets sorted out with my "new" 026 and my "old" MMWS 261CM. The 026 is running 16" bar with 3/8th x 0.063 Carlton semi-chisel (no safety hump strap) which it pulls just fine. I'll use it for limbing and other nasty work. The 261 is now running an 18" bar with 3/8th x 0.063 Oregon 75CL (thank you @radio ) full comp, square ground. It was absolutely VICIOUS bucking 14-16" oak today.
Ryan Browne
9:29 AM
Wisconsin
Nice bars! Saws aren't bad either. :)
Does the 026 feel quite a bit smaller/maneuverable? I've owned an 026 and a 261, but not at the same time.
Blackgreyhounds
10:29 AM
S. Central PA
Yes. For sure. I need to weigh the pho's though. I think the plastics on the 026 are slimmer, which probably subconsciously make it feel lighter and nimbler.
Tpagel
9:29 AM
Central IL
Thanks to @Tpagel for the Cannon bar, too.
You are very welcome. A well ported 50cc with factory square sounds awesome.
I really like a saw you can't stop no matter how tough you get with it.
Nice pic of your 1121 and 1141 and serious bars!
Sent from my SM-J327V using Tapatalk
10:29 AM
Sounds like you need to try a 461, the off idle torque is rediculous for a 70cc class saw imo
Blackgreyhounds
10:29 AM
S. Central PA
Got the powerheads on the scale today, fuel and oil full: 026 = 12# 8oz., MS261 = 13# 7#. So, the 026 is basically a pound lighter.
Ryan Browne
9:29 AM
Wisconsin
I wonder what makes the 261 so much heavier?
It's got a longer bar. Also the bar on the 026 is a reduced weight bar. And it's the original version of the 261, not the newer lighter one.
10:29 AM
I thought he weighed the PHO?
I am guessing the 026 was stock, not ported?
All saws run well. That red oak looks hard!
Blackgreyhounds
10:29 AM
S. Central PA
This was PHO weight. Bars were not on them, but fluids (gas and oil) were full. Yes, this was the original MS261 C-M, so a little heavier than the current gen 2.
026 is stock.
Love my 261 and 361, they definitely "run well." Have had the 026 for about a week, still working on fettling, too soon to have an opinion
Chestnut/Rock oak is actually a "white" oak species, fwiw. Either way, it is definitely solid, hard wood.
